bwhalerfan
"Hey,
I have been trying to h
"Hey,
I have been trying to help my father get his boat up and running and have hit a wall. We replaced the celenoid and that did not help. The battery has a full charge. We have tested to make sure there is power going to and from the celenoid. Also power is going to and from the switch. When you turn the key it just clicks gently. I noticed very tiny movement in the spinwheel. No apparent other noises. I double checked to make sure all connections were tight. The path from Battery to engine is Battery --> Throttle/Switch --> Engine.
All connections appear clean and tight. And again there is power going to and from everything from what I can see. Anyone have any ideas on what might be the issue? My thoughts are it might be the starter. My dad thinks it might be a bad ground to the ignition. How can I test these two possiblities and if you think there is another possiblity how do i test for it?
Derek"
"Hey,
Derek"
