engine won't start in neutral
straygatt
I have a 1976 Reinell with an OMC 800 sterndrive. The problem is I was pulling up to the dock and once I put it in neutral the engine died. It wouldn't start. It only starts in drive or reverse. If I try to start in neutral it just bumps the motor. What could be the problem? Any thoughts?
That has the electric shift correct? Hopefully it is not the shift switch in the controls bigbucks. Do you have a schematic? Disconnect the interupt wire at the ignition and see if it starts in neutral?
