Contusioncharger
Hi, if i had hair I'd pull it out right now. i have a 1971 Johnson 125hp. I had to rebuild the engine do to a broken piston ring. I have been trying to get it running all weekend. I have everything set as the manual says, slow speed screw 7/8 of a turn out, timing at 5, throttle closed, line on cam aligned with the center of the carb linkage. The problem i have with it set like that it only run with the key in start, once it starts the start goes down but i have to leave the key in start as soon as i let it go it dies. If i raise the start lever to full it runs on its own, but no less then 3500 rpm. I just tired this. i removed the throttle cable, moved the carb linkage so it stayed close, and used the idle speed screw to move the timing lever. Move it half turn out. i got to about 1 o'clock with the lever and it started right up and idled at 1000.I haven't checked what the timing was at, getting late. My question is why? Could i of installed the distributor wrong, i used the messing with car. It seemed like it only went one way. But i think it maybe be off. Like a tooth off in a car. Thanks, I did try this method which was the same result as before, only running with the key in start.
i do have spark. As I can get it running if the timing is advanced a lot. Only thing I can think of is if I left out the rotor pin and the rotor is off or something. Will look at it tomorrow.
