M
mangell
Guest
"Any advice appreciated - I ha
"Any advice appreciated - I have a 1990 2.5 hp Mariner that I'm using on a sailboat. The sailboat has a very shallow transom. I currently have the motor mounted on a articulating (lifting) motor mount. The mount is already positioned near the top of the transom. In the up position, the motor is completely out of the water. In the down position, the motor is submerged to about mid shaft (I can only position the motor up or down, not in between). The water is over the cavitation plate and I believe the exhaust port. Will running the motor in the down position damage the motor? Does this motor (a 2 cycle) typically exhaust below the water line?
Thanks!!"
Thanks!!"
