scandalousiii
"2000 Maxum 3300 SCR T-5.7L B-
"2000 Maxum 3300 SCR T-5.7L B-2
Engines, manifolds, risers, elbows all new spring 2007
I Launched on saturday, all good, but when i planed out,i noticed port motorclimb to 210 deg.
I backed out of throttle, temp dropped to 165. I watched it closely and replanned, again it would run at 170 then climb rapidly to 190-220 and fall quickly back to 165 170.
I returned to the marina andran it in the slip. at 2500-3000 rpm,it would warm to 170 then it would spike to 190/210 and quickly fall to 170.
Manifolds and elbows feel COLD, T-stat housing is cold. intake manifold is warm/hot under the t-stat housing.
I replaced t-stat, still same.
I replaced the water pump, thinking i had a wiped impeller, (Old one was fine) Symptoms still same.
I took the boat out again,and the same symptoms ..... seems to run at 170 but the guage spikes to 190/210 and quickly returns to 170-175
I removed the water hose (raw water to t-stat housing) and have a full flow of water into a boucket.
Both engines have always run at 175 deg showing on guage. ALWAYS.....
Is it possible a bad sender or guage??
Tom"
Tom"
