Keep'r Wet
Engines run within temp under all RPM and Load Ranges, never going above 175F. But when I slow the boat from plane at say 3500 RPM to Idle, Temps jump up around 200F to 205F and set off 200F Temp Alarm. I'm assuming this is because the belt driven water pumps slow down when the engine slows and the high heat generated from the Higher RPM cannot be expelled quick enough. But is there another issue? This shouldn't happen. What Can I do to fix???
Thanks,
-Jon
Thanks,
-Jon
