1992 evinrude 40HP. E40TLENJ oil injection setup.
purchased boat over the winter. it was properly winterized.
today: charged battery, new spark plugs, mixed half tank old gas/stabil with half tank of new regular unleaded gas. new oil.
tried to start it up, took a couple tries and it started, but died right away. did this several times. keeps dying within a few seconds. fuel bulb needs to be primed between each run. I suspect air in the fuel line maybe? no visible fuel leaks between the tank and the engine. the fuel filter (I think its the fuel filter assembly, plastic tank looking thing that I can see gas in) seems to be the culprit for why the bulb needs to be primed each time trying to start it - it is about 1/4 full, prime the bulb a couple times to fill it up and get the bulb to feel full/hard again.
started maybe 4-5 times today but dies right away, within a second or two - I tried priming the bulb while it was running to keep it running and that is when it ran the longest, maybe 5-10 seconds.
Now it won't actually start, cranks and cranks but doesn't seem to catch and actually start up.
stuck on what to try next, could it be the fuel pump? that was my next thought but now it won't turn over and actually start.
really wanted to get it on the water this weekend, first nice weekend we've had this year!
