ParagonTrojan
I have twin Chrysler 400's with Velvet trans and V drive. 1 motor will idle fine and rev up ok. When shifted into gear the rpm drop off and it stalls. I am very inexperienced with mechanics but have had some help so far. This is what I have done:
-Fuel filters
-fuel pump (mechanical)
-Coil
-Distributor cap and rotor
-plugs
-Rebuilt carb (could not locate new metering rods)
-Compression test is good
The engine definetly runs smoother now but still drops off when placed in gear. Vacuum guage indicated low vacuum. Tried advancing the timing and it does improve but can"t seem to advance it enough.(turned all the way). Adjusted carb settings but the screw on the right had 0 affect on vacuum. The motor did overheat badly last year but ran ok afterwards.
Anybody have suggestions for me? I am at my wits end
-Fuel filters
-Coil
-plugs
