Yes, everything runs fine after i gun it to get it started. But once i turn it off, the problem starts again.
The carb was just rebuilt, I was just about to take it off and noticed my choke was not connected, could that be the problem?Sounds like a idle air mixture to me do you know when the carb was rebuilt last? Do you let it warm up first? Does the choke close when the engine is cold? You can try adding 1/4 turn rich on the idle air needles and see if it improves. Ricardo will know better on how to approach the issue do you know the history of the motor. Tune up, oil change, plug wires, carb rebuild, drive oil change, lube points? The first step is to allways do a compression test with a fully charged battery engine cold then get back with the results!
