I have a 2005 Sea Ray with a Mercruiser 5.0 L V8 Alpha One . The motor stalls when doing a slow excelleration. It starts up good, idles good and stays running after you shift it into forward or reverse as long as you don't try to push it to far past neutral. If I push on the throttle (back and forth) like pumping the pedal, it won't stall. I have changed plugs and fuel filter. Boat has approximately 400 hours. I know this may be a repeated topic, but I couldn't find any other ones related.
