Im back again, i still havnt armed myself with a manual but forgive me for that as ive learned more terminology.
Alright, ive read up on common problems for engine cut off when selecting gear, main suspects being shift cable and shift interupter switch.
Something is going on here with the interupter switch not disengadging shifting into forward but i want to give a little bit of back story just in case the switch is preventing damage.
I removed the leg to rebuild the water pump and being an amature it could not have been put back on properly, i was adviced that "if i got the gears wrong that could cause it to cut off"
Also the first time i pulled the control box lever into reverse after putting the leg back on it was a bit stiff but gave way and has been smooth since(engine off)
What i do know though is reverse engadges fine and back to neutral fine but when i go into forward the switch will push on and not come back to neutral (with the engine running or not). When i pull back to neutral the switch will disendgage again so it seems its in unison with the control box.. im imagining this sounds like a binded shift cable.. but i also know that it use to work when i bought it; only things i have done to the boat since is
- flushed coolant
-removed and replaced leg
And sprayed the engine with 'linolin linox' cant remember the name.
Sorry if this was a mouthfull to read just trying to give all the information i can, i can be shorter in the future..?
I have a probly rookie question too;
If the 'gears are wrong' can i fix this with the adjusting procedure of the shift cable ? Dont really wanna drain fresh fluid.
Thanks for your time, a penny for your thoughts
Mercrusier 3.0l alpha one gen I. 86 93 ish..
- flushed coolant
