I have a '96 Larson 194 SEI, 4.3 LX Merc, Thunderbolt Ign, 4 barrel carb, Alpha outdrive - Previous owner stated water in fuel caused some engine stops but my experience has been a sputter and stop after a larger wake. Then the throttle has to be pumped 8-10 times, or more, for a restart.
I have : drained/dried fuel tank
replaced fuel filter - found no water in merc. filter
checked elec. connection plug at back of engine
Spark wires, ignition wiring seems tight
Otherwise engine runs great, pulling skiers or cruising, all day long if no big jolt.
I was wondering if small amount of water was trapped in carb bowls and shaken into delivery with the jarring of the boat?? The sputter is immediately after wake crossing. When pumping throttle to restart, I am getting good streams of something, gas or water, into the carb. but it will not start until I pump what seems way too much fuel into the carb. and my imagination lets me think the liquid does not have a strong fuel odor. I have been reluctant to use a fuel drying additive, I do not want it in my tank, but I would put it in the filter bowl?
Any help is appreciated.
