I have a 1995 Malibu Response with a direct drive Mercruiser 350HO engine that has a throttle body fuel injection system. When I start my engine when it's cold it runs like a champ for as long as I would like. But when I shut if off and it sits for between 15 minutes and even 4 or 5 hours, I then begin to have problems. It starts up fine and even runs for a few minutes, but after 3 to 5 minutes it sometimes shuts down. (more often than not at this point) It then stalls out and acts as though it's not getting fuel. I can try and start it again but it has to sit for a while before it will start back up. When this first started happening, it would start up within a few minutes. As this problem has progressed, it takes longer and longer before the engine will start back up. Sometimes it could be up to an hour and I have actually run the battery down once trying and then had to get towed in. If it starts back up it runs fine the rest of the time it's running. I have not checked the fuel pressure but I have checked to see if fuel is spraying in to the carburetor and it is. Once I tried spraying starter fluid in after this happened and it acted as though it would continue to run as long as I kept spraying but I wasn't sure if it would cause any damage so I left it alone at that point. I'm not sure if it's the fuel pump, the fuel system in general or even a sensor that's not allowing proper fuel flow. Somehow this problem occurs only after the engine has sat hot for a while. What could the heat build up being doing to cause the engine to do this? Does anyone have any ideas or suggestions on how to locate this problem? I don't want to just start replacing parts as a guess. Any suggestions would be greatly appreciated.
