"I have a pair of old (ear
"I have a pair of old (early 1970's vintage) MIE 215's installed in a 23' Uniflite Sport Fisherman. The engines have always run cool. When first started they will warm up to about 140-150 and then the temp drops to 120 (I assume when the thermostat opens). After that they will run all day (starting, stopping, cruising, running hard) at 120.
Recently I replaced one seawater pump. The original pump (which I rebuilt) started making noise. I couldn't find any reason for the noise so I replaced the pump with a Jabsco pump designed to replace old Mercruiser seawater pumps. The pump is quiet, but this weekend I took the boat to the lake and that engine never warmed up. It ran at 105-110 all day.
So...several questions: 120 seems too cool for the engines to run anyway (but they run so well that I wasn't worried) 1)Is it possible that the gauges (Faria out of an old Pacemaker) don't match the senders and are giving low readings? 2)Why would replacing the seawater pump make the engine run cooler? 3)If both engines run well, should I even worry about it?
Cheers,
Kelly McCoy
West Texas"
Cheers,
Kelly McCoy
West Texas"
