Hi All -
I looked back through a few pages of this forum and couldn't find a similar post although I'm sure others have probably seen this issue. How many problems CAN an outboard have? Unfortunately, the search function on the forum doesn't let you choose a specific engine forum, so please bear with me if this has been asked and answered. This problem started at the end of the last season and we thought the carb replacement mentioned below would fix it, but it didn't - so now we're completely frustrated and ready to cause some harm to the stupid thing.
We have a 2008 (might be 2009) Tohatsu MFS20 four stroke outboard. It started developing issues symptomatic of a gummed up carburetor - without touching the throttle it revs up and down; when it's on the downward rev you have to increase throttle to keep it from stalling; stalls fairly quickly if you don't touch the throttle.
We cleaned the carb - that didn't solve the issue. We verified a good fuel stream from the fuel pump when we disconnected it from the carb. We then REPLACED the carb, the external gas tank, the hose from the gas tank to the engine and the gas. We blew out all of the internal hoses leading from the fuel connector to the fuel pump to the carb. We replaced the spark plugs.
Same problem.
Any ideas of where to look next? We don't have a service manual and aren't overly familiar with outboards (give us a diesel inboard and we'll pull it apart and put it back together) so detailed suggestions (vs. you should look at such and such) would be GREATLY appreciated.
Thanks!
Chris
Same problem.
Thanks!
Chris
