I'm in the process of purchasing a 2005 sea Ray 200 sport that has a cracked block due to lack of winterization by previous owner. 20 ft boat dry eight approx 3200#, current engine is 190 hp , 2 bbl 4.3 l V6. I think the 190 hp will be under powered, so weighing options between going back in with a 4.3 upgraded with a 4 bbl or upgrading to a 5.0 as replacement engines are about equal cost.
My my goal is to have a fun, reliable boat that can tow a skier, tube, or just cruise -that is an upgrade from my curretnly owned 1991 Sea Ray 170 w 3.0 (love the reliability, fuel efficency, and ease of maintenace but really underpowered).
Any advice on if the 4.3 w 4 bbl (assume approx 220 hp) will be enough or upgrading to 5.0 is worth the effort is greatly appreciated. If anyone has first hand experince with 4.3 to 5.0 swap and can comment on needed changes that would be great. I'm a very experienced boat/automotive and industrial mechanic, from what I can see to 5.0 would require:
moving front motor mounts forward (there is room)
gear ratio swap in alpha one gen II
new prop pitch
will exhaust risers mate up to the y?
throttle linkage problems
wiring harness.
new prop pitch
wiring harness.
