Yesterday, went out in my brother-in-laws 1999 Bayliner Ciera 2655. It has a 1999 Mercruiser Bravo closed cooled EFI engine. Boat ran great for 1.5 hours, tied up to a mooring to have lunch for 45 minutes, started right up and ran it for another 1.5 hours. Ran at many different RPMs but mostly trolling. We went up river to get gasoline, and as we were approaching the fuel dock to set lines and bumpers we slowed downed, and the engine quit. We could only get it re-started in a "dieseling" mode. No power, barely running, but severely struggling to get gas or air?
Gas tank read about 1/4, and after we got towed to the fuel dock, we put 45 gallons of fresh gasoline in a 75 gallon tank, so gauge is about right. After fueling, engine would start, but quit as the throttle was brought back below 50% or so. Tried several times, all with the same result (run for 10 - 20 seconds and die). Took the filler cap off, same result. Dumped the fuel/water separartor, and after priming, got the same result. I'm heading back to try it today, and I'm hoping it does not start, as I'll never figure it out if it is an intermittent gremlin.
Any ideas?
P.S. I did replace one battery and the alternator last week on this bird, as it had an old battery that was internally shorting (2 volts and heating up) and I'm thinking that it may have affected the old alternator's regulator (ammeter was showing nothing when running). Both batteries read 12.85 or higher now, and ammeter was reading 13 -14 volts all day yesterday when cruising. Internal engine temp all day yesterday was 175 F. When it was running, it seemed to run great, but I don't know if this is an EFI electronics issue, fuel, or air at this point?
Any ideas?
