I hope someone can help me. I have a 2000 90hp Johnson 2 stroke, The guy I bought the motor from said he took off the carburetors and cleaned them then put them back together, The issues im having is when you run above 3700 RPM’s to me it fills like it’s not getting the gas like it should. The motor will surge up and down almost like a fouled out plug. I put new plugs, new primer ball, new filter and still the same thing. IF i stay under 3500 RPM’s it runs like a champ im not sure on the gas milage this older motor is suppose to get but I went 35 miles and only burned 10.5 gallons of gas with 3 people and all our fishing gear. Any help to point me in the right direction would be greatly appreciated thank you.
