Hi there, I have a late 90's model mercury 115hp on my 19ft stratus that I just purchased. The motor will start and idle fine but will not plane out on its own. I have to push in the choke several times then it will finally plane out and run just fine until you back it down. then does the same thing when u try and take off again. Also it only does this when its in the water and runs fine at home. Any ideas I can try will be helpful thanks
