StarCraft 2012
Good morning, new to this forum glad to see there is a place to discuss
2012 4.3 MPI alpha 1
on river couple weeks ago, after a few minutes of running the engine began backfiring and lost power. this is at high RPM and at idle where it would hunt and surge all the way back to dock even at very low speed.
took to mechanic he replaced fuel filter, plugs, and said he cleaned the fuel regulator?!
he stated the pump pressure was good.
when i took it back out for a test cruise after 15 it did same thing. in a last ditch effort I loosened the fuel cap (Vapor lock Maybe)
after couple of minutes it started running normal again. I could not recreate the problem after 45 minutes going back and forth between full throttle and low speed all seemed good.
One question in my head is where is the Fuel tank vent? cap or a breather somewhere else.
am i looking in the right place for the issue?
MM
MM
