ok guys, this one is kicking my ass and has me going nuts.
new engine installed, 5.7, thunderbolt 5 with knock sensor. 4 barrel weber. proffesionally rebuilt carb, new knock sensor, new mechanical fuel pump, new ignition sensor and coil, new plugs, wires, installed remote fuel tank to insure good clean gas. timing checked several times , base and advance system ok. the boat will idle and rev in newutral all day long but put a load on it and out of the gate you hear it pinging, if i do not pull back on the throttle, it will backfire and stall out but start right back up. and act the same way.
