Ok so i have a tach installed on the motor. while idling it is around 750rpm +/- 50rpm. Boat drives very smooth. it is a 145 deltacraft. from what i remember boat plans around 4000 and than can very easily hit 7000 rpm at wot. I took a look at the stamped plate on the motor says in between 4500-5500 rpm for wot, so i keep it around 5500 and no more. What needs to be done here i know i have a stainless steel prop. is it normal for the wot to be that high or do i need to go to another sized prop or adjust something(linkage)
I tried to see if there was a stamped number on the prop but couldnt find anything, i havent taken the prop off... are the numbers stamped inside it?
Carb jets are 56 and 35 if i remember correctly, i recently did a carb rebuild because it wouldn't idle. Also replaced the ignition switch because my key would jam up
What would you guys recommend? the motor sounds great around 5500rpm btw
Thank you in advance.
