90seaswirl
Good day fellow mariners. I have a 1990 Seaswirl Sable Cuddy with an OMC 5.0 stern drive. Runs like a top. Problem is
at 3000 - 4000 rpms the temp pegs in the red. I have done all the obvious tasks ; i.e. installed new impeller kit , changed thermostat , installed new temp sender and checked risers for blockage , which was minimal. My mechanic let me borrow his infrared temp sensor to check manifold and risers under load. I ran at 3500 rpms for about 10 mins and gauge creeped up near red. I back off the throttle and took readings , 119 stbd , 103 port. told him of the readings. he said with a 160 thermostat those are good numbers and water is circulating thru block and that I have a bad temp gauge. I did a diagnostic following steps from my Seloc manual and gauge checked out good.
