Hello Everyone. This is my first post but I have found tons of useful info on these forums in the past...so here is my problem...
I have two Crusader 305s (manufactured in 1979 - installed in 1980 Silverton) with Rochester 4 barrel carbs one of them runs great the other has a weird problem that's been going for two seasons now.
1.The motor starts fine and even idles fine for quite a while...
2.After running the boat for varying lengths of time at different power settings about 90% of the time when throttling back to idle it will quit.
3.After it quits it starts right back up but won't stay running if I put it into gear (forward or reverse).
4.The same motor is not getting the WOT rpm only about 3400-3800 rpm (should be 4400 rpm) and the carb is getting full travel from throttle linkage.
Both motors have about 150hrs and both have rebuilt carbs that have about 30hrs on them. I have replaced the plugs, checked the timing, replaced distributor cap, replaced points, and replaced ignition coils.
Everything I did I did to both motors at the same time and as always the port engine runs great yet the starboard is stuck with this problem.
I'm at a loss...I haven't replaced advance springs/weights in distributor, haven't replaced fuel pump and haven't checked for vacuum leak...
Those 3 things aside does anyone have any ideas what could be causing this to happen?
Thanks in advance!
Thanks in advance!
