Is there any risk in replacing engine mounts in the water - doing one at a time? I'm envisioning a scissor jack to support the corner and I'm replacing and swapping one for the other. If the engine is 1,000 lbs, tranny is 200, than the max each corner is supporting would be 300 lbs which doesn't seem like a lot to me. Rears would be closer to 300, fronts probably less.
Mine are original (24 years) and I'm trying to do my final alignment. A couple of them are hard to turn but the side/side sliding adj on the trunions is a struggle.
Just wondering how practical it is to try this in the water and any scenarios which will take me out of commission. The boat has a 13' beam so access isn't too bad.
Bob
Bob
