Engine losing power above 2500 rpm
CaboJohn
We went out fishing today and I found Iwas losing power on the port engine. Boat is a 2002 Pursuit 3000with two 5.7 Captains |Choice, 400 hours. These engines have theeight bolt, two piece intake manifolds with high pressure pump, fuelrails and individual injectors for each hole.
Up to 2500 rpm both engines seem insinc and throttles stay aligned. As you move above that, the portengine needs more and more throttle to stay up with the starboardengine. It will run up to 3900 rpm but at that point the starboardengine is about half throttle and the port is close to wide open. Byitself, the port engine will only turn about 3100 rpm. So at thehigher rpm it looks that the right engine is pulling most of theload. And we had some 12 foot rollers out of the south so therereally was a load when we would climb them.
We ran for about 45 minutes at 3900 rpm(23 knots) this morning. I could not tell if the power loss was dueto a miss or fuel issues or what. It looked kind of weird with thethrottle settings so far apart. At fishing speed (1800 rpm, 7 knots)everything seemed normal and no difference was obvious between theengines. Running back at higher rpm, the same low power issue wasevident.
I want to do some troubleshootingtomorrow. Any suggestions as to the best approach will be welcome. I strikes me that fuel flow (filters) and fuel pressure are the placeto start...although it would be easier to pull plugs and look for adead cylinder due to ignition issues or a clogged injector. Or wouldit? As I say, all suggestions welcome.
Thanks!
CaboJohn
Go to AutoZone and borrow a fuel pressure tester. Hook it to the fitting in the fuel log then take her for a ride. Have someone monitor pressure and you'll know if it's fuel or ignition related.
I'll bet the pressure drops when the motor sags.
Jeff
I don't think he has one close, down south of the border...do concur w/ jeff - start with the fuel pressure (and just buy the gauge - they are cheap). Once the engine is running , fuel pressure should be up to the regulator setting (like 35-40 psi) and it needs to stay there thruout the entire RPM range.
I am going to bring down the two filters I need and see if that does it. I will also bring a gauge for fuel pump pressure. I that does not do it, is there any point in having my local pickup truck mechanic come over and read codes?
CaboJohn
For the most part, the low pressure side of the fuel delivery system is independent of the ECU, until the most recent models.
No ECU control = no codes if an issue exists.
I guess where I was going with the question about codes was to ask what else the problem could be. I will change the filters and check the fuel pressure to see if it is correct at high rpm. If this does not lead to a fix, then I am guessing it could be clogged injectors, ignition issues or what? I likely will not get back until the fall and then I want to be ready to run it down. Any thoughts?
CaboJohn
