1989 3.0L had ignition changed to electronic; coil gets real hot; do I need a different coil when changed from points and condensor system?
It is not the gas.
ok run a wire straight from the pos side of the battery to the pos side of the coil. Run it that way see if the coil gets hot.
To shut off the motor you need to pull that wire off the battery or install a switch.
