engine help
Stick
My engine will start and idle fine in my driveway revs up fine I got to the lake it was hard to start it is sputtering badly put it in gear it dies turn the key to startback no response turn the key three times it starts but it is still sputtering real rough only 5mph 1989 90hp johnson pro series
If the engine cranks over slower when in the water, read on...................
(Engine Won't Start or Hard Starting In Water)
(Joe Reeves)
The Evinrude and Johnson engines, starting in 1973, have what is called Magneto Capacitance Discharge ignition, self contained, not dependent on battery voltage. The engine must turn over at least 300 rpms in order for the flywheel magnets rotating past the stator ignition generating coils to supply approximately 300v AC to the powerpack(s), which in turn is needed to supply power to the coils etc etc (spark).
In the water, exhaust back pressure is encountered due to the fact that the exhaust housing (housing between the powerhead and the lower unit) is filled with water. This would drag down the needed rpms, affecting ignition.
Normally the clue to this type problem is that the engine starts fine on a flushette (hose), but is very difficult to start when in the water.
Should this be the case, check the battery, clean and tighten all conections (use a wrench or pliers, not your fingers). Any cable that gets overly warm or hot indicates either a loose, or tight but dirty, or internally corroded cable. And of course check the starter itself.
They sound " nice " in the driveway running on 3 of 4 cylinders.----Start with a compression test and check for strong spark on each lead.------Spark must jump a gap of 7/16" or more.---Saying that you think you have " good spark " is not the same.
