Engine help
shelby
"need help on my 1989 INVADER
"need help on my 1989 INVADER engine type is a AQ131 120 HP. Everything starts up fine idles ok I bought it from this guy who hasn't start it up for about a year. My dad and I did the tuned up replace the spark plug wire/sparkplugs as well, oil changes. I also added a fuel filter from the tank going to the CARB. I went to nearest lake to test it out; once again it ran ok at about 3200rpm close to 30mph. I notice something that wasn't right sometimes when I throttle it fires back (BURST) on the carb 1 to 2 times. After that it seems like it's lacking of power or I guess there's HESITATION. But after putting it neutral and throttle again it seems to be ok, I mean power is there don't get wrong I don't know a whole lot about boat engine performances. The symptoms seem to come and go for some reason. But for AQ131 running a 3200rpm at about 30 to 35 mph is that normal or more to be expected??? HELP!!!"
I bet you have points installe
I bet you have points installed on unit. I would install a pertonix electronic ignition and replace the coil with a 3 ohm coil. Do it and you will love it.
