Engine has no spark Joe can you help
gerald
" I am not getting any spark t
" I am not getting any spark to either spark plug. What parts should I check and how to check them? Power pack, voltage regulator, stator, or trigger?
'96 Force 40 hp. "
" Gerald..... Sorry, I have no
" Gerald..... Sorry, I have no knowledge of any engines other than Evinrude and Johnson outboards.
Joe (30+ Years With OMC) "
" Gerald,
If you need help go
" Gerald,
If you need help go to the iboats web site and someone in the force/chrysler forum should be able to help you out with your problem. "
" Gerald...The motor you have
" Gerald...The motor you have has a mercury style ignition system. You most likely have a stator failure unless the motor has the new RED stator already installed. Mercury had a recall (although no longer active) on the stators. Any mercury dealer can supply you with parts for this motor. This doesn,t rule out other igntion parts may be the cause but odds are with the stator OK...DJ "
