flabob1
Engine F115TXRZ 2001 . A Just bought a used engine and changed the water pump. Hooked the water to it and had flow but not from the weep hole on the right rear side of the engine. Checked for blockage checked OK as far back as I could go. On the water during a test run there was water flowing. I started the engine with the ears on and I had flow. This is the first engine I have seen that you have to start the engine to get flow out the weep hole. Is that true for this engine ???
