This engine will fit precisely as intended. The only issue that we have with the later SBC, is the tooth count/size of the flywheel.
The AQ series Flywheel Cover (bell housing in the auto world) will NOT allow for the 168 tooth flywheel. So, the 153 tooth flywheel that works with the later crankshaft flange, must be used.
This flywheel is a later Camero car application.
MichiganMotors can supply you with one, or you find one from a Camero.
This later engine may require an electric fuel pump. Be sure you know the criteria for using an electric fuel pump! (i.e., oil pressure shut-down, and start by-pass)
NOTE: make dang sure that you replace the PDS bearings in your F/C before putting this back together.
The bearings and seals are very inexpensive, compared to the damage caused when the aft-most bearing eventually fails on you.
Trust me on this one!
Get back in touch if you need details on this...... as there are several important "does/don'ts" to this!
I can suggest how to purchase these for under $45! And good US bearings, NOT Chinese!
Remember..... the Volvo Penta drive will ONLY work with a standard LH rotation engine.
Also, there is an initial engine alignment, but it is quite different from that of Mercruiser, OMC and/or later Volvo Pentas that are Gimbal system suspened.
Good luck with the project!
