"I have an '84 mercuiser I
"I have an '84 mercuiser I/O that runs great until it warms up. After it warms up it will not run right at speeds above 3300RPM. It surges as if there isn't enough fuel in the bowl. The motor is a 152 cubic inch GM motor. I have replaced the rotor, points and condenser, dist cap, wires, plugs, fuel pump, fuel line, fuel filter, cleaned the fuel tank, cleaned the carb and replaced the seals and check ball and adjusted the float. I'm out of things to replace - any ideas."
