flabob1
I have twin 2005 Yamaha 150 HPDI engine. At Idles the left engine runs a little rough at 600 -700 rpm. Advancing the throttle ( out of gear ) just over 2700 RPM drops and will shout down if not returned to idle .Thinking it is a fuel problem I have changed the fuel filter ,fuel lines and removed the check valve at the tank and it checks ok. The right engine runs ok . I assume that the tank vent is OK. Any Idea what's not happening above 2700rpms . Any help will be appreciated. Thanks
