Engine degree temp difference
jameek
i have about ten degree temp d
i have about ten degree temp difference between the two engines port=about 170* starb.=160*. Is this a major problem?
"No, not at all. It could mer
"No, not at all. It could merely be a variation in the gages or the thermostats.
It could also be from a hot water heater plumbed into the cooling system on the cooler running engine.
Unless there is a dramatic change in the readings, I wouldn't concern myself with it."
"I assume you obtained these r
"I assume you obtained these reading with an infared temperature gun, so you know they are accurate? I hope so, for gages can be way off.
Jeff"
