I have replaced both the upper and lower shift cables on my mercruiser motor and am still having problems with the throttle plate not activating the engine cutoff switch when shifting into reverse. The motor shifts into reverse, but makes a grinding noise before fully engaging the gears and going into reverse. I am under the impression that the cutoff switch should temporarily kill the engine so it can shift smoothly into reverse without grinding the gears. I have been thru the cable adjustment procedure multiple times and feel like I have the cables adjusted where they need to be, but the throttle plate is not moving and activating the kill switch. Any idea what could be going on? Could the gears just be so loose that I am able to shift into reverse without temporarily stalling the motor? Is that a bigger issue? My concern is that I am going to damage the gears by grinding them every time I go in reverse. Help?
