The AQ131A engine is a piece of cake to remove..... especially if cantilever hung!
I'd be hard pressed if one took me longer than 1.5 hour to do, baring no severe corrosion issues.
The Flywheel Cover can remain attached to the transom shield, unless there is work to be done in this area.
Once the engine has been removed, the "drive coupler" is also a piece of cake to change.
These are an all steel Borg Warner style drive coupler.
It will look very similar to this Borg Warner drive coupler;
I'd be very safe to suggest that these either work completely, or completely fail.... very much "unlike" a rubber hub drive coupler.
It would be a long shot, but once in a great while, a sliding sleeve may not completely stay engaged into the gear cup. This may be a more likely candidate!
But see my questions below!
- How is the drive oil? It is by chance milky?
- Have you recently switched to a different type of gear oil? (of which is actually engine oil for this drive)
- Does the drive still propell the boat FWD?
- Does the drive allow for reversing?
- Have you tried a different propeller? (I highly recommend doing this)
- Any vibrations?
IMO, the mechanic has not completed diagnostics on this. Since he has NOT...., how on earth can he give you a $1k quote on this?
I'd also bet you that he is thinking Mercruiser or OMC..... not Volvo Penta!
He may be the wrong guy for this!
1.5 hr to remove engine.
Drive Coupler ......... $100
(one on e-Bay as we speak for $65)
Time to install drive coupler...., and re-install engine........ 4 hr if he's very slow.
Do the math.
Yes..... this would be a very user friendly task for a mechanically inclined person IF this is the issue!
Remember, boats are never investments...... they are almost always expenses.
There is simply a cost in owning and operating one!
Point being.... if you need to spend $500/1,000 on this, it may be true..... you still have a $1k boat.
But if you use it 50 hours next season.......
$500/1,000 divided by 50 = $10/20/hr to own this boat.
What else can you do for $10/20/hr, and have this much enjoyment? (minus fuel and insurance, of course!)
And that is just engine run time.
Got any children? They love boating!
This is a good engine/drive..... and well worth repairing if the hull is any good!
