"While reading a boating magaz
"While reading a boating magazine,in the TECH information section,the question was asked "Can I run my 18hp Yanmar diesel from a hosepipe coupling at the top to supply the engine with cooling water from a pressurized hose" The answer given was "A pressurized water supply should never be used to feed the raw water pump of an engine equipped with a water cooled exhaust system. Applying even a low pressure supply of water to the raw water pump creates the risk that the water will flow through the pump when it's not operating,or deliver an excessive flow of water if the engine is operating slowly. Either condition can fill the exhaust system with water,which can back up into the exhaust manifold and enter a cylinder" The advice is to allow the engine to draw water from a container. My question is -- is this information correct,and does it also apply to my 270hp fresh water cooled crusaders? Thank You."
