YellowYaro
I have a 18ft 1978 bayliner quartermaster with aq120b and morse throttle control/shifterBut: I have no throttle cable and the shifter cable is locked up.I'm not so found of the morse shifter set up mostly because I don't know how it works exactly with shifting gears and the design. I'm use to singe arm forward for forward, pull back for reverse. Seeing as I need new cable anyways I was curious what my other options are for a complete shifter controller setup. So suggestions on other controllers Or stick with the morse and just get cables for that Thank you
