Engine continues to run
darwyn
Engine will start immediately.
Engine will start immediately. But when the switch is turned off the engine continues to run. could it be the ignition shut-off switch? when pulled engine still remains running. what's the solution?
"The kill circuit is as follow
"The kill circuit is as follows.
Black ground wire from powerhead ground to powerpack. Black/Yellow wire from powerpack to reaised "M" terminal of ignition switch. Black wire from other regular "M" terminal of ignition switch to ground.
Key ON: "M" terminals not connected (Ignition engaged).
Key OFF: "M" terminals connected (Ignition shorted out)
When time permits, visit my eBay store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
