I have an S175txrv Yamaha oil injected two stroke. Runs great up till a little after mid range. If I throttle higher, it boggs down and will die if I keep it at full throttle. If I back off to mid range, it will pick up and haul butt. I am only able to achieve 3800rpm as of right now.
Carbs are cleaned, fuel lines are good, primer bulb is OEM yamaha and brand new. Fuel pumps are also new. WOT Timing advance is set wide open.
Any help would be appreciated thanks.
