Dylan Pritchard
Once I had the engine running as per previous post, I started looking into the tilt/trim issue on my 1986/87 V6 150.
I found some rotten old wiring and broken pins in the 5 wire connector. On trying to replace this, due to very cold weather 2 wires slipped out of my hand and touched. There was a small bang then engine won't even turn over now. I can't figure out how tilt/trim wires caused the starter inline fuse to blow though!
On checking the wiring I found the blown 15mm 20A fuse (which I cannot source anywhere to replace, so have replaced whole housing with a more standard 30mm fuse holder). I can also see a wire going from the starter solenoid to the junction box for the Trim/Tilt power (non fused version). Could it be the solenoid is shot? I tried jumping the starter motor and it sparked like hell but turned over, which leads me to think solenoid. Or am I barking up the wrong tree?
Is there any way I can "jump" the tilt/trim motor - ie connecting the green/blue wires direct power supply to check soundness. Or cut my losses and take to a professional?
Again any advice much appreciated.
