Elto request
J
Joe Amelia
Guest
"I have a 1938 elto 4252 1.1 h
"I have a 1938 elto 4252 1.1 hp.
It has spark, (new plug), is getting fuel (carb is clean and appears to be working), new gas (50:1) and has compression (I can hear the valves? working, and when I put my thumb over the spark plug hole and turn, it pushes my thumb off).
I am trying to start by connecting a power drill, so there is lots of turning.
It is not even trying to start, so I'm guessing its something to do with timing.
Any suggestions on how a novice can attempt this, or where to start?
thanks!!
Joe"
Will the " spark " jum
Will the " spark " jump a gap of 1/4" or only 0.030" with the plug laying on the block?? There is a difference!
"Joe, one other note - if you
"Joe, one other note - if you do get it going you are going to want to mix at 24:1...."
"Ok, thanks for all that, I&#3
"Ok, thanks for all that, I'm guessing the spark is not strong enough.
any suggestions as to how I get at the points to clean them?
thanks!!
Joe'"
