moresparks
Hi – looking for help on the electrical installation on a twin engine AQ171c’s.
The starboard engine is supposed to have a dedicated starting battery only, but the alternator charging wire is completely missing. It does charge via the b+ which is connected to the starter motor main Positive supply. Is this acceptable?
The Port Engine has a couple of batteries one for starting and the other is the “house” battery.
This isn’t charging as the brushes have broken. I have ordered a replacement voltage regulator so not really a problem.
However all connections on the Alternator are via the B+. According to the manual the Charging sensing wire should be connected onto the D+ which then goes to the Instrument panel via a resistor then feed to other circuits including the renix electronic ignition.
A couple of questions if I may.
If the alternator is not charging will this affect the electronic ignition straight away – The unit has 12volts but I wanted to balance the carburettors and I wondered if I was wasting my time until the alternator is fixed.
I am getting spurious tacho readings on the starboard engine, would this be related or should I look for poor connections? I have checked and tightened everything up including all the earth’s etc as far as I can tell.
Finally – Has anybody improved the wiring / charging with modern digital universal smart regulators or Voltage Sensing Relays and was it worth it?
Thank you in anticipation.
