For the last two years I have had an Electrical System Problem.
Every other year I buy a new Marine battery. I bought a new one this year. We go boating for about two hours or so at a time to practice skiing. When we get done boating, I always have to recharge the battery. I’ve had enough of this problem. I desperately need help.
I have taken both the Alternator & Voltage Regulator to a couple auto parts stores in the area to get them tested. They do not have the manuals anymore. “Too old” they say.
I want to purchase the schematic and test procedures for testing the Motorola Alternator & the VR.
I am a technician and can build a test fixture if I knew the testing procedure.
Today I connected a VOM to the battery while boating. It read 13.25v to 13.35v while running 2500-3000 RPM. If I turn on the Bilge Blower, the VOM reading drops to 12.75v. Bilge Blower draws about 4 to 4.25 Amps. The Alternator seems to be putting some energy back into the battery.
How do you test for diode failure in Alternator and a weak or dead VR?
Assuming that the VR is the most likely failure, I called Correct Craft to get a new one. They can’t get any. This is serious.
What is special about an Alternator & VR for Marine use?
Can I replace them both with an Automotive set?
MUST the Voltage Regulator MATCH the Alternator?
The smallest auto alternator I found so far is 60 amps output.
Are Alternators made to turn only one direction? Note Engine is a RH rotation.
I am listing the following specs for the boat & motor and the Motorola parts:
1972 Correct Craft 18 ft Ski Nautique, High-Performance Ski Boat
Mfgs SN: 1998, Motor No. 250-RH (250 HP), 351 cuin Ford (blue engine)
Marine Engine Converter was Crusader
Mfg by Thermo Electron Corp., Model: CO-250 (HP), Spec. RH, Serial No. 81346
Mallory Electronic Ignition
Motorola Alternator
12v Model # M12NCM451, Neg. Gnd., Serial #9582, 35 Amp, Type B
(What does Type B mean?)
Motorola Voltage Regulator (VR)
Model R2CM1 failed. Replaced the VR in 1985 by a thick film type.
Model 8RH20048, Serial No. 23479
Group of three wires: red , black, and green.
One yellow wire goes into the harness. Does it go directly to ignition or thru a resistor to somewhere?
Motorola Alternator
