irrelevant
I have a 26' Glacier Bay with two well maintained, under 1000 hrs Yamaha 150's.
Each engine has its own battery and battery switch allowing each engine to start using battery one, two or both.
Recently an issue has developed which I can't get my head around................
The starboard engine will start easily on battery one or two. The port engine will only start once the starboard engine is running and then only with its battery switch set to both.
Both battery switches are in good condition and working correctly. I have also swapped batteries around and even replaced them with new ones, but whatever I do the situation remains the same.
I would very much appreciate others thoughts on this.
