"My 1971 50hp.is trying to giv
"My 1971 50hp.is trying to give me an ulcer. I have had flawless use from this motor for many years until last night. At the launch I tried to start it but found it was not getting spark. After testing both plugs I was retesting the #1 plug (I always double check my sloppy work) when it suddenly started sparking. I retested #2 and found it also was sparking. So I reinstalled the plugs, replaced the cover (I have a great deal of confidence after double checking my sloppy work)and fired it up! I started and stopped it numerous times and had no more problems all night. If someone has a suggestion on where to start I would be very appreciative. Since I could do little more than look at obvious signs of loose connections at coils and powerpack, I am hoping for a similar experience suggestion."
