I have reached the end of my understanding again. It happens often. I am working on a 1974 Johnson 15. It has a bright blue snapping spark on the bottom cylinder and an erratic and weak to no spark on the top. The top plug was black and oily looking and the bottom was brown as is usual.
What I did:
I removed and cleaned/polished the points on both sides, set them to the correct gap, replaced the condensers. No change. Figured that was the problem but no. I then switched the external coil for the top cylinder with an old one I know to be good. Nothing. I reinstalled the original and decided to swap the wires from the bottom coil to the top. Bam! Same bright blue spark I was getting on the bottom cylinder. So, I eliminated the coil as the issue. I removed the flywheel again and checked everything I had done and looked for any abrasions on the wiring that might cause a short to the top cylinder. I removed the plate and checked the clamp on top and bottom, no damage that I could find.
How does the driver coil alternate spark to the sides? Like I said, I have reached the end of my understanding and need some help. Is it likely the problem?
What I did:
