I went to start the engine after using all the day before and it was clicking using the key. I borrowed a friends battery and jumped directly to my battery. It started and about 5 minuets later the the volt gauge on the dash was maxed out and the RPM gauge was bouncing around and stopped at 5.0 its never been that high. I slowed, shored and turned off the engine the tac stayed at 5.0. I went to start and got nothing. I loosen and removed the positive cable and it was sparking. I cleaned the terminals and the cable end and reset the cable on the post it started. Its started right up,we pulled away from shore and withing 3 minuets the engine died and there was yellowish smoke coming from the engine. It smelled of an electrical fire. It kept smoking until I took a very hot positive cable off the battery. Once the cover was removed the source was obvious. There is a gray, was gray now melted and black, with multiple wires coming from it. It is attached right above the spark plug wire connectors. The numbers on the side are 830179-2 2276. This piece and all the wires coming from it are toast. The wires lead into individual connections that look fine and the wires past that connection seem okay.
What part is that? By replacing that should everything be okay? What caused this to happen?
