"Hello all,
Is the water th
"Hello all,
Is the water that is pumped through the outdrive water pump also used to cool the upper and intermediate as well as the provide water to the heat exchanger? A previous owner of this boat(1970 23' uniflite)installed a belt driven Johnson pump on the front of the engine(OMC/GM350)supplying water to the heat exchanger, it is tee'd into the water fitting coming out of the intermediate. There is very good flow from this johnson pump. My question would be, if the water being pumped through the outdrive is not used to cool, can I eliminate the impeller/water pump housing in the outdrive and get rid of some of the water in the drive causing the shaft to corrode. I know I need to reseal the upper and potentially replace the shafts in the upper, but if I can eliminate some of the water, maybe I can prevent future failures.
And what type of ballast resistor for this motor. can I just get one off the shelf at Napa or any auto parts store.
Thanks in advance"
Is the water th
"Hello all,
Thanks in advance"
